Discuss big scratch removal - how? in the UK Tiling Forum area at TilersForums.com.
F
frogeye
Hi folks
can anyone recommend an easy method of removing a nasty surface scratch to a couple of tiles. I was just raking out a bit of grout with one of those grout removal tools, when I slipped and put a 12" curved black scratch over 2 cream tiles - I can't be the only one who has done it?
Without going out and spending a fortune on some polishing paste can anyone suggest how I make good?
I did make some progress by using grout on a cloth which acted as a fine paste but it is hard going. Vim any good? Any hints gratefully received. What did you do?
frogeye (more suited to gardening now)
F
frogeye
Cheers Andy
not the news I was hoping for but as a last resort I will bear it in mind.
I was grouting a small area in my kitchen when I wondered if the grout paste would have an effect. It did remove some of the line - it's more like a dotted line in places now - or was I just lucky.
As I said I can't be the first or only person to make this blunder.
frogeye
F
frogeye
Ahh T cut - never thought of that. I think my trusty AH frogeye can spare me some.
I will try all suggestions but will get the trusty dremel out with a buffing pad on it. Consider myself the test dummy for tile scratch removal, I will report back my in depth findings. Luckily it's under the sink so I shouldn't cause too much damage
That is definitely the last time I use one of those plasplug grout removal tools. It just skipped over the grout marking the tiles - left the grout unmarked. Dremel plus cutting disc in future.
frogeye (ex tiler)
sibs
nano scrub and a bath rubber - what are they?
Am I really the first person to do this? :yes: (surely not)
frogeye
Nano scrub is a product made by aqua mix its a deep cleaner... has a reputation for getting stuff off tiles where most other products fail. Never used it but have heard anacdotal evidence and also seen before and after photos. Tilinglogistics will know if its likely to work. Its between £10-15 for a bottle (I think 750mm)
F
frogeye
Cheers peeps
I will be trying the vim or what ever my mom has in her cupboard - barkeepers friend or something - I told her I was the bar keepers friend - t cut next. I will report back my findings as promised - will try a before and after photo if I remember - cos I know this site loves photos!
frogeye - serial tile slasher
sibs
I would try the t-cut first before trying these expensive products from aquamix....plus there are better and cheaper products about as well.......
Fair comment Dave..... just thought I'd throw it into the mix.... it may help frogeye to have a few options up his sleeve before he resorts to taking the tiles up. :thumbsup: good luck frogeye hope you sort it without too much expense and will look fwd to yous experimental findings :lol:
mojoammo
No Frogeye, you are not the first, nor to be the last to suffer the injustices of the grout removal tool. If the glaze is damaged the you are screwed and the tilies come out. But this sounds like a mark left from the steel edge of the tool. I use a paint restorer, similar to t-cut, on a soft cloth. Can be tight going but it'll shift the mark if you persist.
Last week laying polished porcelain, before leaving the job I marked the tiles which were yet to set with my red pencil. Next day it took over an hour to wipe the marks off (or rather out off) the tiles, using the restorer and grout dust as a grinding compound. This illustrates the actual porousity of polished porcelain and the need for sealers and stain guards
TilingLogistics
Frogeye you are obviously talking about ceramic tiles here I assume? If so the only perfect way is to replace the tiles. However if you want to try and hide the scratches i would try to buy a box of Jumbo wax crayons and choose the colour closest. Another method is quite often you can buy multicoloured bars of soap in £ shops and get a colour close to the tile and rub it in to the scratches to hide it:thumbsup:
Kev
TilingLogistics
Sorry Sibs even Nano Scrub technology will not work in this situation. Nice thought though
Kev
Reply to big scratch removal - how? in the UK Tiling Forum area at TilersForums.com
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi guys, sorry for long post, just after a bit of advice regarding my first proper complaint...
2 3
14K
How do I drill a hole in a steel bath. Or cast iron bath. Instructions on drilling into baths...
16K
Deleted member 1779
I've just completed a wetroom walls & floors in Regal Vanilla Rock tiles from Topps. These are...
Sean SML Tiling
My goodness - what a palaver!! So, I've been tiling my own wet-room with TOPPS 60x30 Polished...
9K
Billy Hunt
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
