Discuss Bitumen on floor in the British & UK Tiling Forum area at TilersForums.com.
shaundaly
Hi Guys,
After pulling up lino of the floor, this also pulled up the vinyle tiles, leaving bitumen. Bitumen is non tacky, hence they came up with ease. I have heard the words "PCI Primer on here". Am I right in thinking that I can prime over the floor and bitumen and lay tiles as normal. The floor is concrete.
Any help appreciated.
Shaun
Pawelzik
Hello from Germany to Shaun. Before starting tile works check if Bitumen is now in the UK regarded to be a hazardous stuff for human. In former times this wasn´t a question but now it is. So, maybe you have to get it out first, otherwise your client may say you didn´t pay attention and didn´t show him the possible danger that can occur by the bitumen ground under his new tiles. In Germany Bitumen is a problem waste stuff and needs a special waste disposal. Wouldn´t it be the same in the UK?
Remarks to my a.m. message: The Bitumen that Shaun has may be a mixture with tar. Does it smell?
GazTech
Martin...over here there is no problem with bitumen, what Shaun is referring to is infact asphalt...non hazardous.You will find German laws are far more strict than here,bitumen was used years ago to fix plastic tiles internally....this has been been superceeded by acrylic adhesives,and the old bitumen only smells when warmed up to apply....Gaz
Pawelzik
Hello Gaz. Thanx for your advise. I confirm this is the same in Germany, talking about asphalt this is not a problem and a typical, but not loved, ground for tiles. One of our client just finished a supermarket, which was extended and asphalt with sand surface was the ground. Both, the tile layer and the asphalt maker, had to obey a traffic load of 1000 kg/m2 acc. to contract conditions. Therfore the asphalt was a special and very dense and the tiles were laid thin set buttering floating. Regards.
GazTech
Usually large contractors tend to favour concrete bases,vibrated concrete tiled over with solid bed,and expansion pieces at regular intervals.Asphalt is used mainly to tank out ( as damp proof memmbrane) in cellars etc. Concrete is far cheaper to buy than asphalt...so for surfacing floors it is in decline.....Gaz
Pawelzik
True. And me and my clients like concrete more, of cause. I think aspahlt is used when objects need to be reused in a short time as the asphalt can be used in a short time - like the a.m. supermarket. The tilers had 2 weeks for 1000 m2 on the asphalt, meanwhile the active part of the market was still busy and emptied the last week. Then the tilers had 1 week to tile the active part (620 m2) and afterwards, after 3 weeks all in all, the market started business again. It was a tough time for my client but evrything went well.
GazTech
That makes perfect sense...the asphalt is ready to tile on within hours,concrete takes weeks.BAL do make also a green screed compound for concrete not yet set,this seems to be used also on larger contracts .....Gaz
BAL Green Screed Adhesive
A grey, highly flexible, water and frost-resistant tile adhesive suitable for fixing all types of ceramic floor tiles, including porcelain, ceramic mosaics, terrazzo, natural stone (excluding marble) in interior and exterior locations. It also provides enhanced adhesion to low porosity substrates. Suitable for situations where fast track installation is required, i.e. recently laid screeds or concrete. Suitable for use in showers and swimming pools.
Coverage: Depends on the nature and flatness of surface:
Thick bed solid bed trowel = approx. 3.5 – 4kg/m2 Bed Thickness : 3-6mm (up to 12mm in localised areas) Open Time: 20 mins Setting Time: 24 hours Packaging: Available in 20kg bags Shelf Life: 12 months when stored in normal, dry conditions. Protect from damp. Temperature Resistance: -30°C to 70°C Pot Life: 5 Hours
Reply to Bitumen on floor in the British & UK Tiling Forum area at TilersForums.com
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Bitumen on floor
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
