Discuss Black granite tiles - grout gone light grey! in the British & UK Tiling Forum area at TilersForums.com.
smicol
Just had my kitchen floor tiled with 18" "star galaxy" granite floor tiles. The builder used 4mm spacers (which look a bit wide - is this normal for granite?) and "anthracite" coloured grout. The problem is, the grout has gone light grey and looks wrong. What could cause this & what (short of raking-out & re-grouting) can I do?
MICK the Tiler
Spacing of tiles varies it all depends on the quality of the tiles as far as size goes. Personally I like to keep granite at 1.5-2mm spacing for a classy look but 4mm would be considered acceptable.
The discolouring of the black grout is caused by using too much water whilst washing down the grout. Darker coloured grouts need to be washed off with a barely damp almost dry sponge to avoid bleaching or oxide stripping.
A quick fix would simply use a permanent felt tip marker in black run carefully down the grout lines.
Just remember like colouring in as a kid stay inside the lines LOL :lol::lol:
grumpygrouter
The grout spacing can be a function of the substrate you are tiling onto. if you have a timber floor, I personally would lay with a larger grout line than if it was on concrete to allow for movement.
As it was, I feel the builder should have discussed your requirements and views with you before commencing.
Reply to Black granite tiles - grout gone light grey! in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
