Discuss Blow torch gas question? in the UK Tiling Forum area at TilersForums.com.
Colour Republic
Mapp burns hotter, so say there is still a little water in the pipe, you can use mapp and still get the pipe to solder but Mapp can burn too hot in everyday use (when no water is present) so if you're not careful you can over cook the joint and then the solder won't take.
Use the Blue (which was black up until recently) for everyday then if you have a problem joint because of slight water you can't shift, reach for the yellow
Reply to Blow torch gas question? in the UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hello, first post, asking about career change and possible entry route into the industry. I know...
Poynton, cheshire
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
