Discuss Boarding for new stud wall in the British & UK Tiling Forum area at TilersForums.com.
New stud wall being erected in non wet area, only 2.0 mtr X 2.4mtr (w-h) with a doorway. I'm wanting to tile both sides. I know my cheapest option is plasterboard and then prime ( if I go this way which primer should I use ) or can you reccomend any other alternatives
Like Dylante says check out the Mapei Primer G at Tile Giant, then I would go for Keraflex or Kerflex Maxi for fixing:thumbsup: The adhesive colour (grey or white) will depend on what grout you're using:thumbsup:
Painted:yikes:
Yes it will , however, I would run a sander over them Steve mate and try and get the paint off first - just a light sand will do if it's only emulsion, then prime with the Primer G and fix with the P9:thumbsup:
P9 is a lovely sticky to use and won't go off in your bucket:thumbsup:
Reply to Boarding for new stud wall in the British & UK Tiling Forum area at TilersForums.com
I have recently stripped the bathroom. I have 2 walls in non water area. One wall is new...
I am planning to tile bathroom with large porcelain tiles 1200x600 over water-resistant backer...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
Hello all, Joined the forum to hopefully read and pick up advice on tackling some home tiling...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
