Discuss Bosch gtl3 tile laser. Help! in the UK Tiling Forum area at TilersForums.com.
Tomtiler
u still need to find a point to come square off of like say ur tiling a [] i would center the room strike ur line with a chalk line then say ur coming a full tile off the back wall i would get ur size mark it on your chalk line then run your laser so its going down your chalk line then strike it with a chalk line going across the way so your floor is square than as you come back just keep using the laser to make sure u keep square and dont stagger away hope this helps
Gazzer
And breathe !!!!!:smilewinkgrin:
Reply to Bosch gtl3 tile laser. Help! in the UK Tiling Forum area at TilersForums.com
TF Group Please Join
