U
Unregistered
I have fitted insulation sheets on top of flex adhesive, but the result is not good as the sheets are not level. I have slightly raised sections and parts that slope slightly. I started off with SLC, but made the mix too thick meaning it didn't flow properly and refused to level as it set in 15mins. I sanded the SLC and decided I could get the insulation level on the adhesive bed. Wish I could start over, but have spent £400 on materials. Wish I had called in a professional. Can I use SLC on top of the insulation using a better mix followed by adhesive, or can I get the tiles level on an adhesive mix?
