Discuss Bottom wall tile advice in the British & UK Tiling Forum area at TilersForums.com.
Hi, Ive had a low shower tray installed, 27mm height & will be tiling using metro tiles that are 100mm. I also plan to use lvt flooring 6mm thickness.
Would you start with a full tile around shower tray & have narrow off cuts of tiles at the floor or could you suggest a better option?
Reply to Bottom wall tile advice in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
United Kingdom
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
