Deleted member 1779
The most popular box set we have ever produced. A big hit with installers
. 30 Diamond cores in a large heavy duty case complete with all tools.
Keep all your diamond cores together. Easy to spot colour.
Its not hard to work out why this set is a firm favourite with installers. Containing a huge number of diamond cores plus all the equipment required to use them efficiently. If you are looking for something substantial and you dont want to break the bank then buy direct from the factory
INCLUDES FREE CLAMP FOR THE 115MM DRILL !!
What is it ? | How much would it cost |
5 x 6mm | 5 x £7 £35 |
6 x 8mm | 6 x £7 £42 |
1 x10mm | £15 |
1 x 12mm | £15 |
1 x 14mm | £15 |
1 x 16mm | £15 |
1 x 18mm | £18 |
1 x 20mm | £18 |
1 x 22mm | £18 |
1 x 25mm | £25 |
1 x 28mm | £25 |
1 x 30mm | £25 |
1 x 32mm | £25 |
1 x 35mm | £25 |
1 x 38mm | £25 |
1 x 40mm | £30 |
1 x 45mm | £35 |
1 x 55mm | £35 |
1 x 60mm | £35 |
1 x 65mm | £35 |
1 x 115mm | £60 |
12 x guide plates | £24 |
1 x guide clamp for 115mm | £40 |
1 x J-hook | £2 |
2 x sponges | £4 |
1 x heavy duty case | Bright yellow and easy to spot. Extremely durable tough shell case |
£600 | Total seperate value of component parts £600 |
[SIZE=+3] [/SIZE]
| [SIZE=+3]FACTORY DIRECT SAVE 20% [/SIZE] [SIZE=+3] [/SIZE] |
This 3KG box really is the ultimate solution with 30 diamond cores in the most popular sizes and also now with and ever wider choice of sizes. Give yourself the best set on the market and grab it while you can at this price. Once we hit retail with it the price will go back to £299 which is still £250+VAT. Retailers are already asking us when we can supply so we wont hold onto this price forever. Included with the kit is our latest innovation the stainless steel push clamp for the 115mm. |
THIS LARGE BOX WEIGHS 3KG (ABOUT THE SAME AS THREE BAGS OF SUGAR)
Every single diamond core drill plus some more is included in this set. As a company we are very used to providing small kits and packs ideal for installers who just wanted to tackle a few pipe sizes. But this kit gives you the freedom to access any size drill core and not have to wait. Whatever the job throws at you then you can be sure you have the perfect diamond core inside the case. Never have to wait about on jobs for stuff to arrive. |
At that price its a no brainer!! Yes I want one....
We put a huge amount of stock into the case so that you never have to be worried or caught out. The bright yellow case is in the colours of construction so that you cant lose it. And it looks cool as well. Did you know we make everything IN ENGLAND. And we have selected the best foam for this set. Not many people get excited about foam! But we do... And we know that every part of this set is superior. Obviously you can tell just by looking at the picture but you can be sure UK craftsmen have spent time and love creating this selection box. |
Having a box is so handy because everything has its place. If a bit is missing then its obvious. Also its easy to grab and carry. And when its time to start drilling you want your equipment to be organised and to hand. The diamond cores are of exeptional quality and standards. Each has been tested by an independant UK company and approve stamped. We used a third party testing company so that retailers as well as installers can be sure of the results. |
