Discuss Brick & Block / Concrete Floor - Do I need to tank? in the British & UK Tiling Forum area at TilersForums.com.
Ripmaster
Hi. First post. Fount the forum whilst searching for cutting tool hire info.
I am currently building a new house and have planned a wet room in the main bedroom en-suite. Construction is block work and concrete floors throughout. My question is, do I need to tank? My builder/plasterer and tiler all say that they don't think it is necessary. Bathroom designer says that I should (up to 5 feet high) to be on the safe side. Plan is to plaster the walls (sand and cement scratch coat) and cast the linear call in the sunken wet area. The drainage is via a 1100mm QuickDrain at the back. the entire bathroom will be tiled floor to ceiling in ABK porcelain tiles with 2mm spacing and Mapei grouts. Any advice welcome. Thanks
Ripmaster
Thanks all for the welcome and prompt feedback. Any advice on the best product?
The bathroom designer has mentioned some liquid tanking product although I forget what it was called. The builder/plaster thought that it would not be needed as they thought it was just a case of going over the top since the room is on the ground floor and thought that the tile shop was just trying to sell me more stuff :)
Wet rooms, at least of the type I'm planning are not run of the mill stuff in my neck of the woods it seems, so lots of hands on experience might be thin on the ground from local pros. The tilers being considered are very good at the actual cutting and installing, and I only heard 2nd hand that they did not think tanking was necessary so I will have to double check that again to be sure. But I will certainly ask the question of them again and ask for justification.
The concrete slab obviously has visqueen underneath, there is also another layer of insulation with visqueen on top underneath the C25 screed that has been poured on top of the slab. The wet area is also quite large 1.2M square with a Clearwater square shower head recessed into the ceiling so the amount of water going to the side walls would be minimal I would have thought. The shower areas is 1.2m*2m with the drying area having underfloor heating and additional screed. So maybe this is why they think spending on tanking is a waste of money. All the internal block walls in question are 9'' hollows too, so no chance of any water bridging to the other side....But I will probably tank it to be on the safe side if that is still the consensus from the pros here.
Here are few pic of what I hope it will look like at the end.
Thanks again for all the advice.
PS: There will be two extractors in the bathroom. One directly above the wetroom area, another for the rest of the bathroom. Wetroom vent will only come on when the shower is used and other will be disabled at that time via automation to avoid air flow 'conflict'. Not shown in the pics, there is a velux in the ceiling above the back wall where the sink and box will go. Althought will not be opened much as only really there for some light.
diamondtiling
A room like that will not be cheap, it looks fantastic. Applying tanking is not just for a 1st floor bathroom or wetroom, it should be used in all bathrooms. It does not just protect from leaks through to a room below, it protects the whole structure as in the walls and floors and gives a 100% failsafe if installed correctly. It amazes me when builders think it is just for making more money and when wanna be tilers think it is a gimmick. Ask yourself this, do you want problems in the future? the obvious answer is no, so dont risk it at this crucial stage.
If you are unsure of the tiler then now is the time to change them.
You could always ring me.................:smilewinkgrin:
Ripmaster
Take on board all the comments as they are all relivant experienced opinions.
My answer would be no.......
Thanks wetdec, would you mind expanding as to why you think no. I'm curious as your are the first to agree with my builder on this - He'll have a field day as I'd told him all the advice I received so far as to tank - I'm just keen that the job is done properly so would appreciate your thoughts.
Thanks again for taking the time.
H
heavytrevy
lmao,
Water will easily go thru the blockwork.
I seen plenty without tanking and the resulting water stains and mildew on the other side is pretty bad.
I would tank above the height of the rose , use a liquid tank , ardex make good ones.
i can link you some detailed waterproofing instructions if you like.
you will need bondbreakers in all the corners and of course a waterstop at the doorway.
Trev
Ripmaster
Hi Trev, any links greatefully received... :thumbsup:
I assume you mean the doorway to the shower area, rather than the doorway to the bathroom. The shower is nowhere near the entry door to the room and is sunken into the floor so would need to fall asleep and block the drain to cause enough of a flood to reach the door I would have though :yikes:
Reply to Brick & Block / Concrete Floor - Do I need to tank? in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm planning to do a herringbone brick floor over a concrete slab with some reclaimed brick...
Hi, all I have just finished my wetroom and tanked all areas, to my understanding because this...
  • Sticky
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
