Discuss Brick slip pointing advice needed in the Canada Tile Advice area at TilersForums.com.
dexo
luton
Hi guys, I've done a few brick slip jobs for a builder that I tile for and enjoy the work, but he gets one of his brickies to point the job once I've finished. But I've picked up a couple of my own brick slip jobs recently and would like to point them up myself, but have never done so & would appreciate any advice regarding mix ratios of sand & cement & the use of a plasticiser & preferred tools would be really helpful.
(the jobs are inside by the way). Thanks.
F
Flintstone
I did this last year. I used a pointing gun and a brickies pointing tool, it wasn’t overly tricky but you need to work as clean as you can. I used a pointing mortar specifically for the job.
Bond
528
Highland
For internal pointing job ( as described) l personally would go with a 1:1:6 mix, cement, lime, sand mix , more working time and more flexiable than just cement/sand. You can add a plasticiser,however, if you use mastercrete with the hydrated lime you may not need a plasticiser. For tooling the joints , first time a 12mm half round jointing tool is perhaps easiest. Personally l prefer a recessed square point). depending on the areas involved it can be quite a tedious job. Good luck whichever way you chose.
Reply to Brick slip pointing advice needed in the Canada Tile Advice area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
luton
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
