Discuss Brick Slips on floor in the Canada Tile Advice area at TilersForums.com.
J Sid
Had a customer contact me a month or so ago, listed building, want old looking brick floor.
They have found and bought some brick's cut into slips from eastern Europe, look ok, so gave a price to fix, grout and seal.
They didn't know what colour grout to go with so did a sample board, but the day before I did it they emailed to say they like the sawn side up.... Ok i thought and did this. Looked what I was, tiles layed up the wrong way....
now I have had a email saying they would like them butt joint and not grouted, lounge floor. The bricks are all sizes and would not work butted.
question is what would you do?
do it or walk?
I
Italy
Old brick, rettificato
Time's Ran Out
First of all it has to be a premium costing.
Is there a pattern i.e. Herringbone.
The size differences can be overcome by selection and block measurement.
Block paviours are using a grouting compound that comes in a tub, add water after its sprinkled and it sets!
We did an internal reception room to blend with the outside block paving. It was meant to flow out, as patios do these days, but they were brick slips cut from a slightly bigger brick! We pointed it with sand/cement on a 3mm minimum joint. More like fixing terracotta but he wouldn't have it oil sealed and it was really difficult to grout despite 4 coats of clear seal .
Good luck. It could look tremendous.
J Sid
herringbone,yes
25mm thick and they want textured side down, cut/sawn up.
these are like soft reds but a very light coloured red. Yes very terracotta ish.
was looking forward to this job, not now.
I think if they don't want to do it the right way I will walk....
J Sid
would ask for pic John but probably done before coloured photos were available:)
Time's Ran Out
herringbone,yes
Not sure there is a ' right way '! The cut edge will have a smoother finish and if oil sealed could look worn and aged.
Your not going to get many similar projects so it should be a really interesting job - but only if they except a premium value.
J Sid
yes John, was really looks for to it. The sort if jobs I like every now and then. A chance to give a premium finish with a different material.
I'll speak to the customer and point out the down side of what they are wanting and see what they say.
Time's Ran Out
There seems to be a frenzy of new look floors about - end grain wood blocks, pennies, epoxy coatings, tiled planks, etc but you can't beat a bit of original side of brick!
25 years ago I did an apartment in reclaimed quarries - reclaimed from the sewers in France - we get all their sh*te!
J Sid
well finally got to lay some floor yesterday. Customer showed me a pick of a 14th century rough floor and said, like this please, but was still thinks to leave un grouted.
layed and sealed them, and the wife loved it, an American and turns out the husband is a architect. 2 in 1 week, but that's another story.
so they are now going to live with it for a while.
Reply to Brick Slips on floor in the Canada Tile Advice area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
