Tiling Tool Suppliers
Discuss Bridge tile cutter for large 16mm porcelain tiles in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
If you're a landscaper or doing outdoor work a more appropriate bit of kit for this is the FLEX CS60 WET. Google it.
The main advantage being that it's not size limited. We used to use these to cut up 3200mm x 1800mm granite slab with two rails joined together.
Hadn't considered one of those... Will it cut dead straight and leave zero chips on the edge?
With the porcelain only having the texture pattern on the surface, I can't have any chipping at all. Not a problem with stone of course!
Is there a reason why you might choose a brige type cutter over one of these?
Reply to Bridge tile cutter for large 16mm porcelain tiles in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
I need a tile cutter gor 600x600 Italian porcelain and am close to pulling the trigger on the...
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
Popular Tile Cutter Threads
dorset
    Votes: 5 4.1%
    Votes: 11 9.1%
    Votes: 7 5.8%
    Votes: 33 27.3%
    Votes: 16 13.2%
    Votes: 31 25.6%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.7%
    Votes: 18 14.9%
    Votes: 13 10.7%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
