Discuss Brutus pro1100 wet saw in the UK Tiling Forum area at TilersForums.com.
gamma38
1,058
Bedford
Hi, just thought i would give this saw a review as i haven't found one on here. I purchased mine from Topps about a month ago, I got mine for what I considered a bargain £380 inc. I did haggle and push mind. I have put it through it's paces and give it plenty of stick using it daily to cut travertine, porcelain etc. There are a few points I will say about it, you should use the grease nipple fitted on the guide rail, sounds obvious I know but I didn't straight away and wondered why it was a bit sticky on the push. The plastic followers on the other side seem to be handling the job ok, I would say that these may prove to be a weak point over time but they would be easily replaced either with genuine parts or a local machine shop would be able to make some out of nylon or bronze for not much money. I have found that if you try to force or push too hard that the motor mount lifts up slightly resulting in the cut going slightly off line, slow down and it's fine though. Overall I have found this saw to be very good, accurate and wouldn't hesitate to recommend it to anyone who hasn't got the money for the dewalt 24000. Cheers all.
gamma38
1,058
Bedford
I am still just using the standard blade supplied with the machine, which to be fair is not too bad, i suppose that is linked to the motor mount moving when i'm cutting sometimes. I'm expecting too much from it and giving it too much stick. I have been looking at the marcrist ck850 i think it is, which seems like a good all round blade. Not cheap though. Any suggestions would be good.
Reply to Brutus pro1100 wet saw in the UK Tiling Forum area at TilersForums.com
Hi I am about to build a small wetroom (900 x 1850) and will be using an AKW former. The...
One Day
Hi all. I'm new to the forum and after a bit of advice on a new wet saw. I've read all the...
5K
hi im selling my wet saw can be used for marble tiles ect the is not a small wet saw im looking...
8K
H
Just got a call from a 6yr client. I installed this wet room and last night it pissed a leak and...
H
Hi guys, I just done a tiling course. I am a plumber to trade and served my time and have since...
Aston
Bedford
Business Name
Tile 2 Perfection
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
