Discuss Bullnose & mitring in the UK Tiling Forum area at TilersForums.com.
Concrete guy
As for the dry diamond profile piece.. Do you have different sizes or if say you got the 12mm, would it do a thinner tile as well?
If you're asking about the mitre bit then yes that will do pretty much any size up to and including 12mm but that's because it's an unusual design. In so much as it's cutting a profile on the back edge of a tile that won't be seen. These are new as you probably read on the thread where I was discussing the design.
However the full bullnose profiles are sized to a specific workpiece thickness.
A half bullnose can be used on pretty much anything from the work piece size upwards. i.e. an R10 half bullnose could be used on 10mm, 12mm, 15mm, 20mm etc etc. It will simply cut an R10 radius on your workpiece.
Reply to Bullnose & mitring in the UK Tiling Forum area at TilersForums.com
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
I'm not having much luck in getting a straight answer out of Topps Tiles so wonder if someone on...
Bullnose & mitring
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
