Discuss Buying a DeWalt D24000 (if you have one please look) in the Canada Tile Advice area at TilersForums.com.
TobysTiling
Hi, I have a job coming up which is 900 x 600 tiles and I feel it's time for my to get a large cutter.
I know EVERYONE raves about the D24000 so this is my first choice really.
Could anyone suggest alternatives or is this deffo the cutter to go for?
If you own this cutter will I be able to cut 900 length?? Easily going to be with the largest tiles I've ever used.
Thanks in advance.
CJ
1,088
Somerset
Or this.
David - Tradetiler
Full D24000 spec taken from our web site (in case you hadn't seen it) where we have a large collection of photos too
Features:
  • Stainless steel rail system is integrated into the tile saw frame, ensuring super accurate cuts
  • Relatively low weight allows one person to transport and set up saw
  • Integrated 45/22.5° feature for quick angle cuts
  • Plunge feature allows the user to make quick plunge cuts
  • Dual water nozzles can be adjusted on the blade in order to minimise over-spray and mist
  • Rear and water trays can be placed on the tile saw to catch over spray - keeping the water in the pan
  • Removable cutting cart for easy cleaning of tile saw
  • Repetitive cut guide with two positions - 90° & 45°
  • Integrated portable residual current device (PRCD) circuit breaker for increased user protection
  • Power Input: 1600 Watts (240v) - 1500 Watts (110v)
  • Wheel Diameter: 250mm Bore 25.4mm
  • (Wheels as small as 150mm can be used but we recommend 180mm minimum)
  • No Load Speed: 4200 rpm
Dimensions:
  • Main tray 690mm wide x 890mm long
  • Using back tray increases length by 400mm
  • Sliding cart 430 x 430mm
  • Side extension table adds 230mm to right
  • Using side drip tray increases overall width to 900mm
  • Height adjustable to 3 levels
  • Weight 32 kg
Cutting Capacity:
  • Max cut length: 760mm (plunge and cut)
    (can be increased to over 1,000mm by plunging and turning tile)
  • Max cut length: 660mm (no plunge)
  • Widest tile cut in half at 90° 660mm
  • Widest tile cut in half 45° 450mm
  • Max depth of cut: 95mm (Motor pillar 150mm back and 330m to left of blade)
Includes:
  • Folding leg stand with adjustable height
  • Extension side table
  • Side and rear water collector
  • 2 x hex key and blade spanner
  • Support leg set
  • 30 day 'no quibble' money back guarantee
  • Free 12 months servicing contract
  • 12 months guarantee
  • 1 x FREE end of year service (You arrange with any local registered DeWalt service centre of your choice)
  • DeWalt Premium porcelain blade
Tradetiler - DeWalt D24000 Wet Saw
Reply to Buying a DeWalt D24000 (if you have one please look) in the Canada Tile Advice area at TilersForums.com
Hi everyone, I'm getting towards the end of a major renovation that has taken 4+ years so don't...
Hi everyone, I really need some pro advice as I have just had a bathroom fitted and the tiling...
Deleted member 53945
Hi guys, Last time I posted here I was having a first attempt at tiling the walls in a shower...
Waluigi
Q
A customer asked me to lay a run of travertine window sill tiles with a half bullnose to match...
8K
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
