Discuss Can I swap my RTS timer for a Time switch instead of using a smart meter? Electrical Advice in the Electrical Advice area at TilersForums.com.
Can I swap my RTS timer for a Time switch instead of using a smart meter? Discussion ThreadCan I swap my RTS timer for a Time switch instead of using a smart meter? Electrical Advice
Hi
Not an electrician, so would have a pro in to do this if its possible to do.
I have economy 7 for my heating and have brand new Quantum wi-fi enabled heaters: 3 X 1.5 KW 1 X 1.0 KW. Hot water is from bottled gas using Rinnai 55KW instant hot water boiler. Heating in bedrooms (3) and bathrooms (2) are by panel heaters with one heated towel rail.
I have an old style rotating disc meter connected to an RTS timer. I don't want a smart meter. I believe that before RTS, mechanical (Venner) time switches were used, and some of these are still in use, so those folks won't HAVE to move to smart meter. Question: is there a modern day equivelent means of replacing the RTS time unit with a sufficiently rated mechanical or electronic timer (or timer and suitably rated contactor unit), instead of a smart meter?
Can I swap my RTS timer for a Time switch instead of using a smart meter? for the original thread on Electricians Forums
Reply to Can I swap my RTS timer for a Time switch instead of using a smart meter? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
