Discuss Can I tile onto this? in the America Tile Forum / Advice Board area at TilersForums.com.
ben209384234
Hi,
Can I tile directly onto this? I have taken off the previous tiles and (most) of the adhesive. Can I tile onto this wall? I have read that you should not using pva under any circumstances, but the wall does feel a bit dusty.
Any advice greatly appreciated!
Trigger
483
uk
As long as what is left is solid yes you can, although it might make your life easier to start with a flat surface. I’d also be reluctant to tile over paint.
Don’t use pva, use a proper tiling primer such as bal apd or sbr as per instructions on the tub.
Lastly think about the weight of the tile/adhesive/grout. Plaster holds upto 20kg per m2.
Dave
Staff member
Subscribed
389,924
1,000,000
Co.Durham
I would be concerned about those loose blocks firstly. And no you cannot tile directly to a backing coat. It requires skimming or re-boarding first.
Get those loose thermalites sorted first though. Dry lining could be the answer.
Trigger
483
uk
As Dave says.
Initially looked like sand and cement backing coat to me.
Reply to Can I tile onto this? in the America Tile Forum / Advice Board area at TilersForums.com
Hello I wonder if anyone has of the attached tiles I could buy from them or something that is a...
Lilygrace
L
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
USA Tile Forum Popular
America Tile Advice Trending
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
