Hi,
I'm currently prepping my new bathroom for plastering before tiling and am unsure about Hardie backer meeting plaster. I have some old brick walls with original plaster on and some new stud walls. The tiles are porcelain so to heavy to fit straight to plaster and they are hexagonal being finished in an up and down random edge so no straight edge to work to, my plan was to fix 6mm Hardiebacker to the brick plastered walls and over the plasterboard on stud walls, finishing just short of where the tiles will finish leaving enough for the skim to finish flush with the hardiebacker and the tiles can be run just over the backer boards onto the plaster. I hope this makes sense. Is this the answer, what would u suggest if not? Any help/advice would be great! Thanks
