Discuss Can I Use Tilemaster Anti Fracture Matting Over A Ply Sub Base in the Australia Tiling Forum area at TilersForums.com.
L
lmkitchens
I'm fitting a walk in shower this week and it is the first i've done!
I'm read up and taken in all of the information on here i hope. I've pulled the existing sub floor up to install the drains and move pipe work and for ease I was going to ply and over board with PCS boards.
The former tray is 20mm so if it would all work I could potentially use TM anti fracture matting to decouple the ply and not have to build the former up another 6mm.
If I'm ok to do this can I tank the matting, I assume I can?
I can always speak to Tile master tomorrow to discuss.
Thanks guys, Luke
L
lmkitchens
I'm building a 18mm ply base level with the joists for the former - Yes a cement cover foam core tray.
I hoped to then ply the rest of the floor sealed on back and sides as mentioned above ^^
So that would leave my ply 2mm lower than the tray in theory
Lay TM anti fracture matt over the ply, maybe run into the former a few inches?
Tank all joins, tray, wall etc.
No UFH
50mm mosiacs in the former
300 x 600 porc on the rest of the walls and floor
Walls are tanked PB so weight isn't an issue
Is this ok to do?
Reply to Can I Use Tilemaster Anti Fracture Matting Over A Ply Sub Base in the Australia Tiling Forum area at TilersForums.com
Hi, I have a tiler turning up next week to tile my refurbished bathroom. He always uses Rocatex...
Apologies if this has been asked before and I suspect all tilers have their individual...
I'm about to lay an anti-fracture mat onto plywood, does the ply need any coating before I lay...
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
Hey all, first post, first time tiler... Throwing myself into the deep end, I'm about to rip...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
