Discuss Can limestone tiles be laid on a floating floor without cracking? in the British & UK Tiling Forum area at TilersForums.com.
Caleyfox
Any help really appreciated
New build concrete floor has masses of central heating / water pipes running across it.
Decision to lay limestone tiles (large 24" x 12") over a 83 sqm area not communicated to plumber.
Now have a concrete floor with 2" timber battens at 300 mm centres and 18mm plyboard on top.
(When heating / boiler is on, pipes will generate a lot of heat under the plyboard).
Can anyone give any guarantee as to how limestone tiles can be laid in this situation?
What I don't want is for cracking of tiles / grout several months down the line
wetdec
I have been advised that the limestone is 12mm thick and is gold eider limestone - similar to Jerusalem limestone apparently.
So then it is quite a hard stone with fischers in it and at only 12mm would benefit from either :
Over boarding existing new floor with a 6mm ply crossing existing joints
OR
the use of ditra or durabase CI matting to relieve deflection.
If these tiles are to be laid as a straight lay I personally would say 1 of the above is essential.
tiler
GazTech
there is some good advice on this post but you originally asked if there is a guaranteed method for this installation and the truth is there isnt all you have is whats called, best practice, which is covered by the advice you have above ,you should be alright if the floor is stable 18mm ply ditra matting good luck
Good posting Gary, good advice......Gaz
Caleyfox
Thanks Gary.
You are right with there being no guaranyees only best practice in the circumstances. It is a case of shutting the gate after the horse has bolted but I have received very useful guidance and methods to pass on to my tiler from this forum.
As a newcomer who only joined Friday, I am amazed at so many people going out of their way to help someone. Good on yer Tilers!:hurray:
TilingLogistics
As a matter of interest I was wondering if you had actually discussed this with your tiler? 83M2 of Large format limestone laid Brickbond is not an easy task by any stretch of the imagination over such a large area. I am of course assuming there will need to be expansion joints incorporated and laying out to run into other rooms.
I am in the process of correcting a similar job right at this moment which is slightly larger 135M of Large format limestone 600 x 400 laid BB running through 4 rooms in a barn conversion. The job has been laid without any expansion joints and over UFH and the tiles have lippage everywhere. I have to grind the whole lot flat install expansion joints and hone and polish to get it right and all because the tiler had never dealt with such a large floor before.:thumbsup:
Kev
Reply to Can limestone tiles be laid on a floating floor without cracking? in the British & UK Tiling Forum area at TilersForums.com
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
gamer1
Hi all, I was hoping to get some input/help on this situation. Background: We had 12 x 24"...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
