Discuss Can someone help!! New bathroom question in the Bathroom Tiling Advice area at TilersForums.com.
GPMANCHESTER10
Hello there - I'm searching for advice from tiling professionals.
I am in the process of fitting a new bathroom suite in my smallish sized bathroom. The original bathroom was fitted with tiles that go half way up the walls from the foor - (From this point to the ceiling the walls were just painted). When I took the tiles off they seemed to have been fitted with a robust concrete style adhesive. This means there is a large lip going all the way round the room and the walls are now completely uneven. I want to tile the walls from top to bottom but this isn't possible at the moment because of how uneven the walls are. Can anyone suggest the best course of action??
Is there a product to thicken the sections of the walls that were not not tiled to make the whole walls even and flush - I understand it might be easy to just plaster but i've been told this might cause problems with tile weight as well taking a long time to dry and I can't afford to be with about the bathroom for a long period.
I hope this makes sense and would appreciate any advice!
doug boardley
what are the original walls made up of?, either way you'll have to remove the emulsion from the top half if you're going to tile it. My advice would be to remove all the existing and replace with 12.5mm plasterboard in non-wet areas and 12.5mm plasterboard (tanked) in the wet areas. If your tiles are going to weigh more than 28kg m2 then I'd use hardiebacker 500 instead of plasterboard.
Polishtradesman
This maybe similar to one of the walls in my parents bathroom, which I did for them a couple of years ago (I also live in Manchester BTW).
One of the stud walls had a steel mesh, which had been skimmed with a cement render, and tiles stuck straight on it. Was a right pain removing the 2 layers of tiles that were stuck to it!!
I smashed off the old cement render and pulled off the old mesh (cutting fingers many times...so if you find the same thing, get some tough rigger gloves to protect yourself).
I then re-boarded the wall, as that particular stud wall was in a dry area of the bathroom and was only due to be skimmed and painted.
For your wall, if it is in a wet area, and your using ceramics. I would plasterboard and tank the whole wall.
If the wall is in a dry area, and your using ceramics then plasterboard only would be good enough.
If your fixing porcelain or natural stone, then definately use cement backerboard for stud walls, or something like marmox boards with mechanical fixings, if going on to solid walls.
Hope that helps, of course if that is the kind of wall it is.
Ofcourse, let us know if you have any more questions.
Best Wishes
Reply to Can someone help!! New bathroom question in the Bathroom Tiling Advice area at TilersForums.com
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
