Discuss Can you recommend a grout for Mosaic in the British & UK Tiling Forum area at TilersForums.com.
Gazzer
Copied from Mosaic Fix Spec
"GROUTING
Grouting can be carried out as soon as the adhesive has cured, typically
after 16 hours depending on the type of tile and background. Use an
appropriate grouting material from the wide range of BAL cementitious
and epoxy grouts, i.e. BAL MICROFLEX, BAL EASYPOXY or BAL
MICROCOLOUR grouts.
Pre-grouting paper-faced mosaic:
1. Pre-grout mosaic sheets and remove surplus before fixing.
2. Place mosaic sheets in position and tap down to achieve full contact
with the adhesive. Ensure that the joints between sheets match the
joints between the mosaic tesserae.
3. Wet and carefully remove paper before the adhesive hardens
completely.
4. Clean off surplus adhesive and grout from the face of the mosaic.
5. Complete grouting."
F
Fred
"GROUTING
MICROCOLOUR grouts.
completely.
I've used Bal mosaic fix for fixing and grouting. I was only suggesting a method.
Reply to Can you recommend a grout for Mosaic in the British & UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hi everyone, Our tiler has done a really amazing job with our kitchen flooring, but has used a...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
