Discuss Can you use normal plasterboard when tanking? in the British & UK Tiling Forum area at TilersForums.com.
Mike Mike
Simon, yes you can use plasterboard when tanking. The main differences between plasterboard and other board materials is the weight of tile and adhesive they can hold. Plasterboard can hold 32kg / m2 if it hasn't been plaster skimmed, or 20kg if it has. Some backer boards, or Marmox type boards can take up to 60kg / m2.
In answer to your other question, isn't plasterboard just as good as backer boards etc, I would suggest that if you are only tanking the shower / bath area and not the whole bathroom then backer boards, or Marmox boards are a better option, because plasterboard will go mouldy over time when exposed to moisture. But there are no regulations or requirements to use superior sheet materials, and plasterboard is definitely cheaper, so ultimately it's personal / client's choice.
Perry
There is nothing wrong with using plasterboard. IMO cement boards are better as they will offer more defense against any moisture from the other side of the wall (leaking pipes and what not) as well as from the tiles side but they are more expensive.
That's true but would rather cut plaster board out than cement board if it gets wet from the other side we have a problem lol
Reply to Can you use normal plasterboard when tanking? in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
I'm a DIY'er refitting a bathroom and en-suite and with 2 showers to tank/waterproof. One I...
Dumbo
Hi all, I'm not much of a forum poster, and am also new here to this one. Additionally, in...
6K
GoneGuy
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
