• Thread starter Steveuk
  • Start date
  • Replies 0
  • Views 118
Discuss Capped gas pipe begging oven Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hi all. Hope you are well.
So I fitted a new induction hob today for my father and whilst the old hob was off I saw that the old gas pipe for an old gas hob that has been capped off with a solder fixing is touching the back of the oven housing. I pulled that oven out slightly and it is not pushing the pipe much, like 1mm, but just wanted to check if you think it's ok to be touching the back of the oven? I mean it's not going to get hot enough to mess with the solder joint is it?
Thanks in advance.
Capped gas pipe begging oven for the original thread on Plumbers Forums
Reply to Capped gas pipe begging oven Discussion Thread in the Plumbing Advice area at TilersForums.com
Plumbing Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
