Discuss Capping the water supply in the British & UK Tiling Forum area at TilersForums.com.
rockyroo
Hi, Merry Christmas everyone
Just wanted to know what the best way to temporarily cap the water supply when you have removed the toilet and sink if there is no shut of valve on the pipe. Obviously will shut the water off from stop **** and then drain hot water, but I will need to leave it a day or two and can't leave them without water. I did see a sort of plastic stopper once but cannot find the name of it, any help would be greatly appreciated. Cheers
F
Fekin
Speed fit stop ends, cheap to buy and very very easy to use.
You can get them at B&Q or any plumbing suppliers
For a toilet it will most probably be a 22mm pipe, just measure it before buying one.
You simply push the stop end onto the pipe and it will make a mild click, if that, and that's it, to get it off you just pull the little collar up and remove once done, and can be reused.
plumbersmate
me thinks you've done this a lot, fekin :yes:
F
Fekin
Push fittings are good to stop water flow temporarily, but it would be best to fit service valves to origional copper pipes, then fit flexi chrome pipes to them and the taps etc. PS toilets are normally 15mm as are sink pipes. Bath pipes tend to be 22m.
Not done much plumbing, so I could only go on my previous experiance's, and bath and sinks were 15mm and the toilets were 22mm.
silverfox
Hi, thanks for the advice, went to my local shop, got some grey ones, the guy said that you have to push them on and then unscrew them to get them off, does that sound right??
Yeah, same type of thing m8.
Some have to be dismantled to remove them and the internal ring of teeth which is whats left gripping the pipe, needs to be sliced to remove it. Throw away once used.
Reply to Capping the water supply in the British & UK Tiling Forum area at TilersForums.com
Hi all, thrown myself in a the deep end and have bought porcerlain tiles for my bathroom, i have...
Bubblecraft
I just wanted to stop by and say "hello" from the other side of the pond, currently living in...
Bubblecraft
Installing LED lighting into tiles is becoming more popular as well as other lighting effects...
15K
Deleted member 1779
4,858 of 4,965 people found the following review helpful 5.0 out of 5 stars Oh the shame...., 3...
New Mexico Chili Cookoff If you can read this whole story without laughing, then there's no hope...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
