Discuss Cappucino marble 450x300 wall tiles adhesive help in the UK Tiling Forum area at TilersForums.com.
John the spark
Hi all, this is my 1st post on here, been searching for an answer for 2 weeks to this, so thanks in advance.
I am about to begin tiling my bathroom with 450x300 marble.
Walls are stud partition, lined with 10mm.ply, plasterboarded, with 6mm marmox boards stuck with tile addy and screwed to the ply with marmox washers (I was told this was fine by marmox tech support, they only say 10mm min so people don't use the 6mm direct to stud work).
i am planning to use keraflex maxi white to fix the stone.
from what I've seen on these forums this is the way to go, just wanted to be sure before I order,
as it states on the mapei info, suitable for stone (provided not sensitive to moisture)' not sure what this means
also will I have to back butter the stone, if so do I do this with notched trowel & walls with notched
thanks, John
Alan.P
Hi John sounds ok, a bit of overkill on the wall prep but hey ho, as for the adhesive, it will be fine, by sensitive to moisture they mean a stone / tile that could stain, as for fixing, use a 10mm notched trowel ( minimum in my opinion ) and back butter the back of the tilw with the flat side of the trowel, as if buttering bread.
Hope that helps.
Oh, work clean, wipe off any adhesive with a damp sponge as you go, allow the adhesive to dry out totally before sealing the stone.
John the spark
Hope that helps.
Hi Alan, thanks for the advice helps a lot
John the spark
Hi and welcome....Your nearly bringing your walls out by 30mm with the ply, plasterboard and marmox.
Could've had 300mm studs centres for the 10mm marmox.
Hi, yeah didnt realise about the weight issue till the walls were boarded and skimmed, couldnt bring myself to strip it all back to the stud, so went with the 6mm marmox, you live and learn..
Andy Tiler
1,043
manchester
Hi Andy, and thanks, as Alan says i will be taking my time (bathroom is weekend distraction from running electrical contracting business) will standard keraflex maxi do the job?
Hi John, if you've got Mapie your better off phoning the technical line to see if its Suitable for what you are tiling.i don't use Mapie mate so not sure? Pay someone to do it an have the weekend off.. ;)
John the spark
hi Andy, rang mapei today, they said keraflex maxi was the way to go, they also confirmed the stuff b&q have badged as mapei super flexible adhesive is keraflex maxi.
thanks
John
Reply to Cappucino marble 450x300 wall tiles adhesive help in the UK Tiling Forum area at TilersForums.com
I'm searching for 42 pieces of 12" x 12" Verde Alpi marble tiles. Preferably honed. 12" x 24"...
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the...
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
