Discuss Ceilings in the UK Tiling Forum area at TilersForums.com.
Be careful with the pvc ceiling as if you have sealed spotlights (ip65) were the bath or shower is. It will eventually leave rings around the light through cause of the heat. Stopped using them 2 years ago because of this issue! Just a bit of a heads up
60 degrees so I see, but how would I know the temp of the lights ?
Reply to Ceilings in the UK Tiling Forum area at TilersForums.com
