Guest viewing is limited
Discuss Cement board vs ply under tiles for wet UFH system in the UK Tiling Forum area at TilersForums.com.
Hi there, we have just installed a Hetta UFH system.. they recommend a 6mm plywood over the top before tiling. I called them and they admitted that ply is a poor conductor.
Does anyone have any experience with cement board (such as Hardie backer or similar) to improve thermal transfer in these cases? Screed not possible.
Many thanks
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Is it already encased in a flexible screed?
If so go straight over with that flexible adhesive for screed. Don't need another barrier between it. (somebody will need remind me of a name)
The fact the guy said plywood means he doesn't know what he's doing with the tiling part or hasn't updated with the times maybe.
Plywood can't be tiled now at all, and certainly not on top of ufh where it will expand and warp and pop apart in the middle and all sorts.
It's terrible cheap stuff we get now it isn't like the solid stuff it used to be.
Thanks all. Can’t use screed over the top of this system. The Hetta instructions say to use 6mm ply as separating layer over the top of the grooved chipboard in which the pipes are running.
Will try and find some 6mm cement board to use instead, any recommendations? Very grateful for all your help.
Reply to Cement board vs ply under tiles for wet UFH system in the UK Tiling Forum area at TilersForums.com
Morning all, I have been given the opportunity to quote for a 110m floor in a chevron pattern...
Hello friends. I am looking for a bit of advice, you would be so kind. I have been a long...
Installing tiles 400x600 over an exposed exterior cement screed - it has 20mm fall over 2300mm...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Leicestershire
What member type are you?
  1. Homeowner
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
