Discuss Cement Boards.... in the Australia Tiling Forum area at TilersForums.com.
SJPurdy
Tanking is recommended in general shower wall tiling to protect a water sensitive substrate from water seeping through the non water proof grout (grout resists water but if the surface is constantly wet then the back surface of the grout will also be damp). Therefore if a cement board is used then tanking is not required as the substrate (cement board) is presumably not water sensitive
Alan.P
Welcome back.
If its in a "wetarea" then it should tanked.
I agree
Not really correct, in certain boards water will pass through the board so it should be tanked, cement boards range but regardless should be waterproofed in wet areas, this drives me mad, if weights allow it then why not use plasterboard instead, tanked is tanked ??
grouchfungus
Thanks for replies. It'a annoying to say the least... Have used cement board for many years and this tanking question is still a grey area..... Knauf say you don't generally have to tank in a shower enclosure situation. However if you ever have a problem with an installation a tile supplier/manufacturer will cop out by quoting BS on tanking etc. So why use cement board in the first place? Using plasterboard and tanking with a decent tanking system ie. The ardex wpc kit will cover you with regards BS's etc. And give
Concrete guy
I used to fit showers in Aquapanel and tank with the BAL system. This was before it was included in BS and tanking was a strange thing that only the Americans and Europeans did. That was just the way I worked.
I figured if I used a structural board and tanked it I'd covered all bases.
The only issue I used to have though was because I specialised in natural stone I would often be fitting a product that exceeded the weight limit of tanking (but not the board), so you had to go without tanking or use mechanical fixings. So sometimes you'd need to think laterally and use an impervious substrate like Wedi board.
There isn't a one size fits all solution, in a domestic environment tanked plasterboard is perfectly acceptable but it's not the best solution and I was always keen on finding the best solution possible that wasn't stupidly expensive.
Reply to Cement Boards.... in the Australia Tiling Forum area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hello all. I'm doing a total refit of my bathroom, including the floor which is water damaged...
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
I'm looking for some expert advice and hopefully some reassurance.... I've just had a complete...
5K
Cement Boards....
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
