Discuss Cement not drying in the Canada Tile Advice area at TilersForums.com.
DHTiling
wow Dave, thanks, that was soooooooooooooo helpful. If it helps, I'm not a tiler, I have never tiled anything before. I'm not a tradesman, I'm a mum who cannot afford the luxury of paying someone else to do something for me.
The word wall tile adhesive didn't make you think then ?
It is highly unsuitable and will not stop down and very unlikely set.
Lift the whole lot up and use the correct product.
Petal
Thank you, a lot more helpful. Since knowing nothing about tiling I stupidly thought that if it would stick to the wall, then it would stick to the floor. Could have probably whipped up a batter that would have done a better job. Will I really need to take it all up? The top end of the kitchen seems to have set but not the other end.
Ajax123
1,213
Lincolnshire
Cor I wouldn't want to be at yours on pancake day... ;)
seriously though wall and floor tile adhesives are made to very different specifications because they have to deal with very different stresses although there are probably some that would do the job. If you think about it the major stress on a vertical wall is shear stress due to gravity where as the floor tile has to cope with compressive and flexor all stresses due to physical loading.
Sadly I agree that the tiles would be best removed and re laid using the correct type of adhesive.
Reply to Cement not drying in the Canada Tile Advice area at TilersForums.com
Got a 100m2 floor to do in 900x900 , floor is chipboard with underfloor heating below, floor is...
Good afternoon, Does anyone have experience of using grooved dry screed boards? (Bonus points...
I'm tiling a 20X20 room, and it will require a lot of cuts around the edges. My question: Would...
Hi, I need an adhesive suitable for 20x20cm cement encaustic tiles on unskimmed plasterboard...
Cement not drying
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
