Discuss Cement vs foam core boards in the America Tile Forum / Advice Board area at TilersForums.com.
Kilo
Norwich
Hi, I'm about to redo an en-suite after taking it back to the stud. I have been doing a little reading on backer boards (but clearly not enough to be sure what to use!) I have gyp-frame 40 cm studs and an external block wall that needs dot and dab. I guess a lot of people rate Hardie backer. Just wondering what professionals and DIY's alike have used and what you would rate? Ta.
Reply to Cement vs foam core boards in the America Tile Forum / Advice Board area at TilersForums.com
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
Not sure if this forum is broken I can’t see most posts due to adverts, but I’ll give it a go...
Hi All, I’ve searched endlessly for an answer to this and can’t seem to find an answer, so I...
Installing tiles 400x600 over an exposed exterior cement screed - it has 20mm fall over 2300mm...
USA Tile Forum Popular
America Tile Advice Trending
Norwich
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
