Discuss ceramic tiles with mosaic pattern in the British & UK Tiling Forum area at TilersForums.com.
The Legend; Phil Hobson RIP
thinking about it if the whole tiles not grouted the whole mosaic look is lost ok then should it also be brick bond god i hate these tiles
Imho they are a lazy persons mosaic, I prefer the real thing. But customer is always right:mad2: as merle says get the joints right otherwise you will see each tile:thumbsup:
Richard Edwards
Hi Brinkley and Members of TF
Theres a real good trick to laying these single tile mosaics - To get the effect of proper mosaics so you cannot see the main joint lines in the tiles themeselves.
Never install them on a simple block pattern, ie one above the other with ' cross ' joints.
Always install them so that the joints are alway 'T' joints ie 'not one above the other' and try to randomise the spacing - ie position the next row of tiles so that the spacing above the joint is - say 5 mosaics to the left and 5 to the right, then the next row - set the spacing 4 to the left and 6 to the right.
I use window fitters packers - 1mm Green, and sometimes use non and occasional use 1 + the edge of another to achieve the result
Its a little more work but very much worth the effort as the results will look great.
Enclosed - Attached the sort of results that this method produces.
Hope this helps
:thumbsup:
Reply to ceramic tiles with mosaic pattern in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, first timers here... I am tiling my bathrooms and prefer the look & neatness of tiling...
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
