Discuss change in floor levels in the British & UK Tiling Forum area at TilersForums.com.
david robson
hi first post. im an amateur tiler want to lay tiles on a concrete floor adding underfloor heating which requires a 10mm insulation board. this will raise the floor level by approx 25mm with the tiles laid. At the moment the concrete is flush with the adjacent rooms wood floor so i will be left with a 25mm lip. Is this a common problem and how do you overcome the visual aspect in the change of level. Replies appreciated thanks
bal
It is a common problem but thats the cost of having under floor heating and tiles you could use a thinner board under neath i use 6MM wedi board that ll knock 4mm off , where floor meets tiles use a threshhold strip thers all sorts of widths and sizes.
GazTech
Schluter have a range of door profiles etc, failing that a joiner could make a reducer threshold where they are needed....Gaz
PS. Welcome to the forums
Schluter-Systems UK Homepage +44 (0) 1530 813396 - Schlüter-Systems
GazTech
thanks for the welcome and the replies. im a painter and decorator by trade but done a bit tiling for relatives etc (unpaid) This tiling job is in my kitchen just concerned what a 25mm step up will look like visually.
Transition strips are necessary, unless you fancy building all your other floors up an inch...lol
Genesis also have a good range......Gaz :yes:
Reply to change in floor levels in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
