Discuss Changing a ceiling rose to 2 wire light fitting Electrical Advice in the Electrical Advice area at TilersForums.com.
Changing a ceiling rose to 2 wire light fitting Discussion ThreadChanging a ceiling rose to 2 wire light fitting Electrical Advice
Hello,
Trying to change an older ceiling rose into a new light fitting, which only has a 2 cable attachment.
I actually forgot to take a picture of it wired in this time, annoying.
I realise it doesn't need earthing, but there is an additional wire, blue with red casing around it.
Not sure what I'm meant to do with that?
Also assume it's ok to fit the 3 live and 3 neutrals into the one space on the new connector.
Images here:
Light Wiring – Google Drive
drive.google.com
drive.google.com
Thanks!
Changing a ceiling rose to 2 wire light fitting for the original thread on Electricians Forums
Reply to Changing a ceiling rose to 2 wire light fitting Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
