Discuss Chipboard in the British & UK Tiling Forum area at TilersForums.com.
stoner
Hello, hope someone can help me. I have got a job (12m2) of limestone and heating to lay on a chipboard floor. Floor is already tiled with porcelain which i'm going to pull up which has been down a few years with no visible problems. Can i tile straight on top of the chipboard (providing it does'nt pull to bits) or do i really need to put something on top first?
Great site by the way. I have been tiling for 5 years for mainly tile showrooms and just decided to go on my own so heating is a little new to me. Better safe than sorry.
wetdec
Hi
I would, if it tears up removing the tiles put down 18mm ply, if they come up ok then you need a 12mm ply screwed at 150mm centres as limestone is heavy. Overlay the ply with Durabase CI matting to prevent shrinkage/ expansion cracks from heating later down the road.
If you tell us a little more then we can possibly help further
tiler
wetdec
Its probbaly your best move unless you want to insulate the floor in which case maybe 2 layers of 6mm would give you a solid base.
Personaly I am a ply person and think weyroc & ply is ok to overheat which would make the previous post ok.
Existing weyroc
12mm ply
3mm Durabase CI mat
heating cable (not mat)
**Around 18mm to here** If you want to drop to 9mm ply then you will need to neat unibond and screw it to the weyroc
What limestone is it m8
tiler
wetdec
Yes you can, it will give you the insulation property and a surface to work off but must rest on the state of the floor when the tiles are removed eg are they bowed are there high points. Ply laid and screwed down across existing boards has fewer points of weakness in my opinion and is a solid job.
If substrate boards are the way you want to go then I would hold fire until you can see your chipboard and know what exactly you are dealing with.
tiler
Reply to Chipboard in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Chipboard
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
