Discuss Chips on porcelain Tiles in the Canada Tile Advice area at TilersForums.com.
Walshy
I'm having a problem with some porcelain tiles that I just cant seem to get the cuts right without some chipping.
Ive tried wet cuts/ dry cuts. Ive changed cutting disc to a Beava premium diamond on recomendation and while that is definatley better than what I had, unfortunatley there are still some small chips (ive ran the disc through some breeze block a few times to break it in).
I'm taking my time with the cuts, letting the disc do the work etc but still not getting the desired result.
Does anyone have any other suggestions? or even at this stage some ideas to hide the chips, although obviously not ideal I'm starting to think I may not have too many other options as some of the cuts are in very prominant positions.
Any help and advice will be greatly appreciated.
Thanks in advance
John Benton
1,138
Leeds
Thanks in advance
Was it Joe at STS who recommended the Beava ? I've never used their blades, I use the Montolit DNA and blades from ATS Diamond Tools.
Try scoring them with the manual cutter first
One Day
Any photos?
When I face a delicate porcelain I will try and dry cut using a Sigma cutter.
I always find I get the cleanest cut that way.
If it's more than one cut, then I'll score with the wheel anyway and then carefully use my grinder (with Marcrist ck850 accumax blade) about 0.5mm from the score line. That normally will result in a chip-free cut which if needed, I'll smooth up with a silicone-carbide disc on my grinder afterwards.
Any photos?
Got to agree with imp tho walshy, if you need to have your cuts completely chip free, then repolishing the cut edge is the way to go.
Won't mention the avatar imp! ;)
Except, I knew you were familiar! :)
F
Flintstone
Any photos?
What silicone carbide disk?
Reply to Chips on porcelain Tiles in the Canada Tile Advice area at TilersForums.com
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hello Tilers! I am a homeowner in California and I thought I'd come say hi in search of a...
Tilers Forums on FB
