attacama40
Hi there, new to this so bear with me.
We have a large walk in wet room built about 10 yrs back. It was starting to see better days so have just rebuilt it but retained the top section above head height which was perfect condition.
Normal build, studded, backer board, Homelux matting etc. Is about 2mtrs x 1.5mtrs. Have installed 4 body jets, a Giessdorf head & an Aussie Rainshower silder.
Peculiarities: all the room corners are coved to 116mm, including the ceiling. That is why we retained the top section which was built using white Italian glass mosaic tiles...quite expensive.
The new built part (below head height) has been done in cheaper ceramics, 330mm Sq mosaics. Cheaper but look surprisingly good. The coving down the 4 corners was rebuilt & the result is good.
We knew that it would be necessary to probably put a cosmetic break between the new & old section but I didn't realise how hard it would be to find a decent inset chrome trim to put in the grout gap between the old and the new areas.
I looked at the normal non-flexible options but have not so far found anything that looks designed it, more added on.
What I'm looking for: Ideally a thin chrome trim (or similar) trim, maybe 2-3mm thick that could fit into the grout gap. Also ideally flexible so that the 116mm corners can be accommodated. So essentially imagine a 2x1.5mtr rectangle with curved corners.
Worst case we could add a cosmetic surface mounted trim but I think that would look a bit poor. Somewhere someone makes a flexible metal (or plastic finish metal) trim but I've looked all over e.g car trims, carpentry resources etc but so far to no avail. Have read a lot of very very useful material on here during our very long in the tooth renovation & its been a god send. I'm hoping one of you have the silver bullet!
Many thanks for any ideas in advance
