Discuss Chrome mosaic tiles advice in the UK Tiling Forum area at TilersForums.com.
Olz
Use a wet cutter, and go slow. They are small enough that with careful setting out you should be able to "close or stretch" the grout lines to avoid a lot of cutting, too. Take your time and think ahead so that you don't catch yourself out.
I usually use white adhesive with these, too.
Spot on, the last time I fixed these i did this, I've fixed the larger 5x5 ones as well though and they cut ok just take it nice and slow a fine file is handy to have to hand though to deburr the edges where needed.
Reply to Chrome mosaic tiles advice in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
