Discuss Circuit design calculation Electrical Advice in the Electrical Advice area at TilersForums.com.
Circuit design calculation Discussion ThreadCircuit design calculation Electrical Advice
I have a question i hope someone can just give me a little clarification on .
When carrying out preliminary cable design for a given circuit we use this formula = ( milliohms per metre x Length x multiplier Factor for maximum operating temperature ).
Do we still need to use the the maximum operating temperature factor for the given cable type in the above formula if we use the Zs measured value (the 80% rule ) against the protective device .
example
A Radial circuit is wired in 2.5mm 1.5mm , the Length is 25M the Calculated value by design would be ( 19.51 x 25 x factor 1.2 ) divided by 1000 which would = ( R1+R2) as 0.58 Ohms obviously add this value to the Ze and then check against the protective device Zs measured value ( 80% rule ) to confirm is this value complies .
or would we just use the formula this way ( 19.51 x 25 ) divided by 1000 = ( R1+R2 ) = 0.48 ohms added this value to the Ze then check against the Zs measured value of the protective device .
Do we still use table I1 from the on site guide page 220 when calculating by design the R1+R2 or is this not used because of the 80% rule applied to protective devices Zs .
Circuit design calculation for the original thread on Electricians Forums
Reply to Circuit design calculation Electrical Advice in the Electrical Advice area at TilersForums.com
As Im not working today I though I would make a quick how to for any newbies or anyone who may...
user123
U
APPLICATION AND FUNCTION Schlüter-BEKOTEC is a floating or heated screed system for producing...
wivers
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
