Discuss Cleaning and repairing travertine floor tiles in the Best Floor Tiles area at TilersForums.com.
bodie1947
I,ve just moved into a home. th kitchen has got travel tine tiles whivh are very dirty and have holes in them.
I went to topps tiles and thensold me some cleaner , some stripper and some sealer.
The cleaner did nothing. Can anyone suggest a cleaner that works.
Also what can I use to fill in the holes.
Topshop
Re: Cleaning and repairing travel tine floor tiles
Do you mean Travertine?
You may want to call a stone restoration professional to clean and re-seal the stone. Some stripping chemicals can damage the stone and if the sealer is not applied properly you can make a nasty sticky mess that will attract more dirt than repel it.
Fila are a trusted brand amongst tilers so Topps have sold you the correct products, however the job may require more attention than a novice (I'm assuming you are) can give.
The cleaner probably will not do anything if the floor has not been cared for and treated with the correct products over the years.
You are looking at then stripping the floor of all previously applied (if any) sealers etc then starting to take care of the floor correctly if it isnt beyond repair.
As for the holes an mapei kerapoxy jasmine would be ideal to fill them once you have assertained what is happening with the restoring...again, a job for a pro in my opinion.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping some threads related to cleaning travertine. Not all threads will be current discussion but if you would like to reply with some information, go ahead, it may be valuable to somebody in the future. Tile Cleaning and Tile Restoration Forum
Reply to Cleaning and repairing travertine floor tiles in the Best Floor Tiles area at TilersForums.com
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
  • Sticky
Best Floor Tiles
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
