Discuss Cleaning dirty slate! in the UK Tiling Forum area at TilersForums.com.
martyof
Hi guy's I've been called to look at a job where the slate hadn't been sealed prior to grouting. It's mostly fine, but you can notice in the rise and falls of the slate where the grout has nestled into some of the grooves. It was sealed afterwards. In attempting to clean this I was considering taping off all other tiles and doing a mild acid wash to try and get through the sealers and scrub clean the grout. Any advice would be extremely welcome? Will it effect the coloring of the slate?
Many thanks
widler
1,328
England
marty,i used acid on a job i just did,i couldent seal before grout due to certain factors, it was fine,i brushed it on,left it for half hour then washed it down after(i tried it on a old bit 1st,and left it over night,that was fine too),left it to dry then give it a few coats of sealer.
just to add as well, i had to do it on another job as well,left my apprentice to grout it,i had to go elsewhere,made a bit of a mess of it,must of been on his blinking phone all day,so had to acid it,and seal it again, that was fine to.
i just used the TP brick and stone acid
DHTiling
LTP Grout Stain Remover
LTP Grout Stain Remover is the solution for removal of cement and grout residues and is extremely effective against mineral salt formations (efflorescence). Useful for routine cleaning of patios and other outside paved areas, LTP Grout Stain Remover may be used on glazed ceramics, quarry tiles, terracotta and some stone.
Tips: Pick this product if you have cement and grout residues, mineral salt formations, limescale, water marks, dirty patios and other outside areas. Do not use on limestone or when underfloor heating systems are in operation. DO NOT USE ON ACID SENSITIVE SURFACES.
Technical Data Sheet (PDF)
widler
1,328
England
erm,is slate a sensitive surface,if it is,im up la creak without la paddle:yikes:
seriously though,its been months since the 1st one,the bloke i did it for was a slater,loves owt slate,old time chap,and he is still talking to me,even did his orange house floor in westland greens the other month,and the kitchen looks fine:thumbsup:
Reply to Cleaning dirty slate! in the UK Tiling Forum area at TilersForums.com
Hi there, I am new to this forum... And was just after some advise. ( I know this topic has...
17K
I've just completed a wetroom walls & floors in Regal Vanilla Rock tiles from Topps. These are...
Sean SML Tiling
My goodness - what a palaver!! So, I've been tiling my own wet-room with TOPPS 60x30 Polished...
9K
Billy Hunt
