Discuss clementile in the UK Tiling Forum area at TilersForums.com.
clmcg123
i am doing a friends bathroom floor in a couple of weeks.the house has had a large extension to the side,therefor bathroom floor extended about 2mtrs.problem-the original floor is floorboards and the new is plywood.do i cover the whole lot again with plywood,hence making a high step(especially when tiles are on),or could i just prime and adhesive it all AND would it be the same materials i would use on both floors?...ANY suggestions please!!:confused:
Dan
Admin
Staff member
5,091
1,323
Staffordshire, UK
You could do with getting the lower area higher by using plywood and then tile the whole thing. I think. What sort of height difference are we talking about? A few mm? Materials-wise, it's a case of BAL Fastflex on the floorboards providing they are screwed or fixed really well, and two part flex on the plywood, at the most. Or the whole lot with fastflex and if it's just a few mm difference then you could swallow the difference with the adhesive.
If I read your post right, that is.
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
12MM exterior ply (nothing less) over the whole lot is what i would do, you will have to do it on the main floorboard part of the bathroom anyway so another 2 extra meteres is nothing, screw down every 300mm, be carefull of pipes prime the ply with bal apd and use flex adhesives and grouts. Go to Floors To Go and get a door threshold bar for the heights into the room
Reply to clementile in the UK Tiling Forum area at TilersForums.com
I have installed a wetroom form (the style below). I have removed the floorboards and lowered...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
clementile
Tags
usa
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
