Stonebro2
Have lots of unusal display stuff - Travertine Columns - Egyptian Hieroglyphic Freeze 90 x 50cm, Mosaic Topped Tables, Green Granite Tabletop suitable for use outside etc. Room Lots of Stone - all to be cleared by 31/10/2012. Please read and pass on - I would like small monies for items I am Selling - all stands are free have some large tile display stands enough to fill a showroom all FREE Most are like knew 1 a bit battered - Large corner display Cost £3000 - £1000 from factory £1000 Distributor and £1000 from us - FREE Like NEW very modern - Will Post pics of displays. We had a lovely showroom - but having FibroMyalgia and going blind and other health problems its time to stop. ADMIN hopefully not breaking any rules here just don't like kit going to waste!!!
Having just closed a Tile Showroom, I have a quantity of Original Style display stands, if you are an existing seller of Original Stayle Tiles you may have them FREE if you come and collect them. If you are an existing customer you will know how much these stands have cost us - A pretty penny, but things are tough out there and I would hate to see them go to waste.
WE NEED THEM COLLECTED BY 31st OCTOBER 2012 NO LEAWAY
We have
Earthworks large stand
Winchester large stand
Winchester samples trays
Winchester Residence tray
40 - 50 Winchester astted boards
4 x fully merchandised MOSAIC stands
2 x Mosaic back to wall stands for Sample Cards
5 x Victorian Floor Boards & Stand
1 x Artworks Stand – Victorian Wall tiles
1 x Glassworks Stand
2 x Glassworks Spalhbacks wall boards
1 x Glassworks sample tray
1 x La Belle Cuisine stand
1 x set Tileworks boards & loose samples
1 x Odyssey Floor tile tand
If you are not currently a customer but the Rep confirms to me you can have an account then all being well you can have them. If you are only a couple of miles from a key account it is unlikely you will get one
Also have following quantity of SEALANTS & CLEANERS over a 100 Litres £130 NO OFFERS
HG
2 x HG Spot Stain Remover 500ml Stains in Porcelain stone etc
2 x HG Mould Spray 500ml Cleans Black Mould in Baths & Showers
1 x HG Grease Away 500ml Stainless hob backs etc
1 x HG Grout Protector 500ml
2 x HG Grout Cleaner 500ml
5 x HG Cotto Wax Protector for easier maintenance Terracotta 1litre
3 x HG Golvpolish 1litre Satin finish for Quarries/Victorian/Slate
4 x HG Remover 1litre Removes old polish/oil etc deep clean product
3 x HG Quick 1litre Porcelain Cleaner
1 x HG Quick 5litre Porcelain Cleaner
1 x HG Shine Cleans and shines Ceramic /Porcelain etc.
LITHOFIN - all litres unless listed otherwise
7 x MPP Marble Polishing Powder
20 x Eversheen easiest maintenance for Terracotta
7 x Sealant for keeping Terracotta pale for use with Impregnator
6 x Impregnator for Deep seal to Terracotta prior to surface Sealant
6 x KF Tile Polish for Quarries & Victorian (Lithofin equiv to Golvpolish)
3 x Protective Impregnator for porcelain/victorian
3 x Intensive Cleaner
5 x Conditioning Cleaner
3 x Classic Terracotta Primer
1 x Slate Oil for Slate Hearths/Cladding not for use externally or in wet conditions
2 x Wax Off for deep clean Slate Terracotta etc for removing old sealants wax etc.
1 x Care Seal - satin finish for stone
3 x Easy Care neutral ph cleaner for marblr stone etc.
2 x Power Clean cleaning limestone stone etc
1 x Cobblewax - give tumbled marble/trav a lovely long lasting shine
1 x 5litre Cement Away - for removing cement/grout residues - not suitable for marbles/Limetones
1 x 5litre Multi Seal for slate etc
1 x 5litre Resin Seal for Terracotta permanent seal
1 x Oilex 250ml tube - Poultice for removing oil/grease from granite marble etc.
MISC
3 x Ever Build Silicone Eater (mini tubes)
1 x Aquamix Grout Haze Clean up
Regards
David Goff
07743 038919
We have
HG
MISC
Regards
David Goff
07743 038919
