Guest viewing is limited
  • Thread starter Askey
  • Start date
  • Replies 0
  • Views 40
Discuss Cold water flowing back into hot feed. Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hi, I'd be grateful for some advice please. Every 12- 18 months I have a problem with cold water flowing back into the hot water feed through a shower mixer cartridge, causing all hot water feeds to run tepid or cold. Replacing the mixer cartridge fixes the problem, but only for a while.
Would a better solution be to have a water pressure regulator installed to reduce the pressure of the mains cold water? Are there any negative aspects to having a pressure regulator installed?
Many thanks in advance
Cold water flowing back into hot feed. for the original thread on Plumbers Forums
Reply to Cold water flowing back into hot feed. Discussion Thread in the Plumbing Advice area at TilersForums.com
Plumbing Advice
Tags
None
