Discuss College work in the British & UK Tiling Forum area at TilersForums.com.
can't help my self, just love mitred corners. have not used plastic trims for long time, just don't like em and mitred is soooooooo easy to do with ceramic tilesIt all looks good Phil. The only thing I would recommend is you consider trying, and practising, mitring your edges on windows and other external corners. Of course, the task is made 100 times easier with the brilliant new invention, Mitre Wizz. But even without that, as Tony can attest, it is still possible to do satisfactory mitres with a wetsaw.
If you have the freedom to experiment on your course, try mitring. Once you try it, you'll never go back to plastic trim, or overlap edging...
Good luck!
Sorry about the order as am new to this will try and sort it out 18 to 23 was a 2mm model and then the tutor said try the hole wall and patch it to as you can see in 22 the wall had a hole in the bottom mibble and was filled with traning adhesive and left to go off hope that helps.
Reply to College work in the British & UK Tiling Forum area at TilersForums.com
