Discuss Complete re-do in the Canada Tile Advice area at TilersForums.com.
N
needinghelp
Hi ALL
We recently had a ret room fitten but it has turned out wrong, the floor is moving and the mosaic tiles are cracking up the shower area is also moving and when in the shower water runs under the glass screen. it has gone terribly wrong
now it is laid on 18mm floor boards which were in an awfull state and then had a 3mm ply put over the top then tilled but it hasnt worked, the guy who did it wants to put it right, we have spoken and he asked me if i could find out what would be the best to re do the floor with? and what is a good wet room tray as he used a foam one and it seems to be moving, i did find out that with a foam tray if using mosaics that 50mm is the limit and he has used 25mm
so what will be the best to rip out the floor boards and re new with ? and what is a good wet room tray
any help will be really appreciated as he is a genuine guy who has just made a mistake
Sean
N
needinghelp
sounds an absolute shambles,personally i wouldnt let him have ANOTHER GO
I know it does sound a shambles and it probably is but legally i have to let him put it right which is the correct way, he has said he wants to get it right so i have to let him have the chance but if anyone can give advice on what to replace the items listed above with i would appreciate it as i can show him what people recomend and i am sure he will do it right this time
if i dont let him do it i will have to pay someone again and wont be able to get a penny back so i ahve to do it this way
Many thanks
Sean
I
Ian
Sean the problem is that wet room fitting requires extensive knowledge and training, from a tiling point of view it is probably one of the most technical processes. I/we could write lengthy posts giving you a step by step guide on how to complete the job and which materials to use but, it's one of those things that can not be completed form written guidance alone. Judging from your opening post some very basic mistakes have been made in the preparation stage that has led to a catastrophic failure. You need to get a tiler in with experience in wet rooms to do this job or you will be back here again with the same complaint.
N
needinghelp
Hi Brian
The guy in question is actually an excellent tiller but he hasnt done wet rooms he didnt say this, but hey ho i dont have the money to pay for it doing again. Legally i have to give him a chance
the floor boards are shot and he thought he coud strenghen them which didnt work, so what boards flooring does this need replacing with?
the wet room tray was a foam one is there a better on as below this he did put battons along the joists and in fill with 25mm ply and added knoggings so i think he did some right but the 25mm mosaics are not to be used on the foam trays, i have researched this and it says 50mm min
i have told him this and he has appologised and said he wats to get it right he has also said he is bringing another guy who has done them before, but if i have the knowledge on how it should be done then i can show him and hopefully get it right
Hope you can help as i dont have the money to pay for it doing again and i have to give him his chance
by the way the rest of the room is stunning and the kitchen tilling he di is exemplory
Sean
gamma38
1,058
Bedford
Amen to that brother, perfectly put Bri
N
needinghelp
Thanks Guys, I understand what you are saying and I am in this mess but Legally I have to let him put it right.
So a simple question if you can see your way to answer
the floor boards are shot what should these be replaced with ?
after he has replace all the floor and made it 100% solid then what is a good wet room tray ?
this will help lots
Many thanks
Sean
N
needinghelp
Why don't you recommend to your tiler that he comes on here to have a look for the advice that he needs?
Or maybe he has contacts that can do the correct prep work, and he can then just do your tiling, maybe.
Thanks Martyn
He doesnt have the internet and if i do this i will understand what needs doing so i can check on it being done and make sure he does it right, not saying i could do the job but i do know how to check something
Sean
I
Ian
this will help lots
Many thanks
Sean
Ok, strip the floor back to the joists, reinforce with extra noggins.
Screw 25mm ply to the joists.
ontop of this fix 6mm marmox or hardiebacker, glued and screwed with SPF.
you now need to ensure the floor is water tight, tanking is a must IMO.
With regards to the tray, google PHG wetrooms and choose from their site, they are spot on. Don't forget to follow the installation instructions to the letter.
Reply to Complete re-do in the Canada Tile Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
  • Sticky
5K
Matthew7
  • Sticky
Complete re-do
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
