Discuss Concerning EICR coding Electrical Advice in the Electrical Advice area at TilersForums.com.
Concerning EICR coding Discussion ThreadConcerning EICR coding Electrical Advice
Out of interest, what are your opinions on coding what I call 'technical C2s'. We all know what the regs say, and going off that a C2 is a C2, simple.. but there are definitely times when that's a bit grey. For example...
Exposed basic insulation is a straight C2 going by the letter of the book, but what if that exposed cable is caused by a small section of missing trunking 7 feet up a wall in a plant room where it's *extremely unlikely it'll ever be touched?
Or a DB with several holes in the side exceeding the max british standard finger... But that DB is 10 feet up in a locked room accessible only by trained persons?
Would you still code these as C2? Or C3 with a note explaining your reasoning?
And more to the point, if some idiot fetched some ladders and got a shock after sticking his fingers in the holes on the DB for ***** and giggles, would you be liable?
Concerning EICR coding for the original thread on Electricians Forums
Reply to Concerning EICR coding Electrical Advice in the Electrical Advice area at TilersForums.com
TF Group Please Join
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
