Hi
I've got a concrete floor to tile in January and at the moment it is dry and has no damp. Although the plane is even, the floor is not level. I want to put down an SLC to level the floor, and tile, prior to kitchen being fitted. I have the following questions to make sure the customer doesn't have any future problems:-
1) Should I as a precaution put down a damp proof membrane prior the SLC going down?
2) What dpm would you recommend, liquid?
3) Should I prime, prior to putting down dpm, if a dpm is required? (I will of course prime if no dpm goes down)
Cheers
John
Cheers
John
