Guest viewing is limited
Discuss Concrete sub floor, how to create fall? in the Canada Tile Advice area at TilersForums.com.
48
443
Cheshire
The customer I'm doing an extension for wants a wheelchair access wet room.
It's close to the outside wall and foul drain and there is a doorway there at present that will be bricked up so I have fairly good access to cut the concrete for the waste and drain. The only thing I'm worried about is getting fall on the concrete floor?
Spare Tool
...or make your own
48
443
Cheshire
I might’ve misunderstood what you are doing.
You’ve a concrete floor- Impey do a kit for concrete floors. Impey Aqua grade or something.
Its not a new concrete floor, it's tiled at present. I'm wodering if I could cut hte existing tiles back to the subfloor and then overtile/self level the whole area to lose the 20mm
Bill
Height restraints need to be specified for a definitive answer from the many knowledgeable folks on here.
If no probs with height, then I would chop off tiles and create my own falls in a sand and cement screed like it has been done for centuries.
If there is a problem with height, I would rip up the subfloor 'til I could create a decent fall with sand and cement screed like it has been done for centuries.
Boggs
1,118
Uk
I have worked on a few conversions for local councils and they always specified AKW Medicare formers, they are stronger and are made specifically for wheelchair access situations, might be worth a look at what they offer.
Reply to Concrete sub floor, how to create fall? in the Canada Tile Advice area at TilersForums.com
Starting a job soon that has had bison beam (block and beam) installed with UFH wet pipe system...
Deleted member 53945
Hi guys, sorry for the clunky thread title... Just over a year ago we had a side...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
My plumber had to lower my tub drain to fix an issue. I just noticed the threads to the...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Cheshire
Business Name
Acorn Joinery
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
